66-427 trans remove revisited - NCRS Discussion Boards
  • Richard E.
    • 247
    My shifter assembly is the later version (attached to frame). It really appears to me that the transmision could be removed without the need to remove the shifter assembly from the frame (just disconnect speedometer cable, linkage, and wiring). Is it possible to remove the transmission without removing the shifter assembly in this case? Thanks for your responses and special thanks to those responding to my previous questions on the same subject.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66-427 trans remove revisited
    I have always removed the shifter first. It is tight enough with the thing out. I cant imagine why you wouldnt go ahead and get it out of the way. Its really not that hard.
    • Richard E.
      • 247
      Thanks Wayne. Just trying not to make more work, goal is to get the Vette back on the road where it belongs ASAP. Only interested in removing the transmission to assist with pulling the drive shaft so I can replace u-joints. The transmission and shifter is fine as is. (Engine is already out at this time) Any trick to aligning linkage / levers when I reassemble the shifter to trans? Thank you for your input.
        • 43234
        Rich-----
        Remove the transmission to assist with pulling the driveshaft? You need to remove the driveshaft to enable the removal of the transmission, not the other way around. The driveshaft most certainly can be removed without removing the transmission first.
        • Wayne W.
          • April 30, 1982
          • 3605
          Joe is right. I dont understand why the trans has to go to take the driveshaft out, unless its got some other driveshaft that is a one piece. But, if the engine is already out, the trans will come out without removing either the driveshaft or the shifter.
          • Richard E.
            • 247
            Wayne, Joe, you are correct, the drive shaft will come out without removing the transmission. It just seemed that a few bolts would remove the transmission if I could leave the shifter on the frame. May just pull it to degrease it and change fluid. Thanks for the information.
              • 43234
              Rich-----
              If you do pull the transmission, at a minimum I'd take the opportunity to replace the clutch release bearing.
