1990 ZR1 Startup - NCRS Discussion Boards
1990 ZR1 Startup
  • James C.
    • November 1, 2001
    • 137
    1990 ZR1 Startup
    Is it normal for a 1990 ZR1 on startup to go to 2000 rpms for a few seconds, then drop to 1500 for a few seconds, then to normal idle speed. I have been away from these cars for a while and I want to make sure this is not hurting anything. Thanks! Jim
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 1990 ZR1 Startup
    I've started more ZR1's than I care to count and that is the way they are !! All sounds normal to me !
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Tom H.
      • December 1, 1993
      • 3440
      After further research, I have located a bulletin # 47-65-03 Released January of 1994. It calls for the replacement of the MEM CAL "prom". This will reduce idle fluctuation on a hot start. Sometimes a customer may notice an increase in idle speed during decel during a vehicle coast with clutch depressed.
      Might be something to look into. Sounds like yours is normal though.
      Tom Hendricks
        • 43234
        Tom and Jim-----
        I believe that the updated prom was GM #16163905. However, it's discontinued and I can't find any supercessive part number. Finding one might be a challenge---this was a 1990 ZR-1 only SERVICE piece.
        • James C.
          • November 1, 2001
          • 137
          Thanks! My car has the updated prom. I will sleep a little better..Jim
          • Verle R.
            • March 1, 1989
            • 1163
            Joe,
            Services are available that will provide a PROM with contents to match your fondest wishes.....even if you don't need it.
            Verle
