62 340hp Water Temp Sending Unit - NCRS Discussion Boards
  • Tom C.
    • November 1, 1997
    • 94
    I know there has been a lot written on this subject and I did go to the archives first, but has anyone found a source for a temp sensing unit which works properly OUT OF THE BOX without adding resistors to eliminate the high readings? I have a 62 340hp with a new unit which reads about 30 degrees above the values of a direct reading gauge.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 62 340hp Water Temp Sending Unit
    go junkyarding . check out the GM cars of the late 50's to early 70's for the AC Delco temp sending unit. mike
    • Louis T.
      • July 31, 2003
      • 282
      Tom,
      You probably want a sender manufactured by www.lectriclimited.com. They advertise that their sender is specifically calibrated to be accurate when used with an original gauge. (I bought one a few months ago for my '65 L76, but haven't installed it yet, so I can't yet attest to that statement - maybe others can.) Keep in mind that it isn't represented as being totally correct from a judging standpoint - it lacks the engraved writing (AC - MADE IN U.S.A.) around the underside of the hex surface, and I think the upper lip and black plastic insulator are configured differently. But like you, my first priority was accuracy, and I didn't have a convenient source of N.O.S. or good used parts. You can get it from them or from certain other vendors, assuming they're willing to disclose their source (ask). Good luck!
      Louis
      • Tom C.
        • November 1, 1997
        • 94
        Thanks Louis, (and to all who have responded) I think the Lectric Limited unit is the way I will have to go unless I hear from someone who has an original to sell.
        Tom Cheairs
          • 43236
          Tom-----
          Originals come up on eBay quite frequently. They are not rare.
            • 43236
            Mike-----
            Yup; there are a LOT of these things still out there. However, as I'm sure you know, one needs to find one from a car that has a temperature gauge and not just a warning light. The 2 units can appear similar but they are not functionally interchangeable. If there's a gauge on the dash, though, the chances are great that it has the sending unit one is looking for.
            • Mike M.
              • May 31, 1974
              • 8396
              joe: thanks for the education. i wasn't aware the idiot lite vs gauge sending units differed. mike
              • Jim Cear
                Tom, I bought two from Lectric Limited, one was inaccurate, second was OK. Please check any you use with an IR unit to determine its accuracy, I have gone through several for my 63 340hp.
                • John D.
                  • December 1, 1979
                  • 5507
                  Tom, See Fred Olivia for a temp sender. I am surprised no one mentioned that. I am sure someone here has his number. John
                  • Steven B.
                    • June 30, 2004
                    • 256
                    Here's one on ebay now. good luck.- steve
                    • Tom C.
                      • November 1, 1997
                      • 94
                      Re: IR Reading
                      Just how do you get an accurate measurement with an IR unit? Shoot the water hose from the thermostat housing? Or surface of the intake manifold?
                      • Larry L.
                        • May 31, 1993
                        • 101
                        Re: IR Reading
                        Just sent a buch a copy of Temperature sending units that were tested in 04.
                        The comparison is enlightning. I wanted to know how to hold one in my had and measure the resistance and it work in the car. The resistance plots and data are available.
                        Send me you E-Mail Address and I will mail you a copy of data and plots.
                        John - rember seeing them in Knoxville !
                        Larry
                          Re: IR Reading
                          Tom -
                          You'll get a more accurate reading if you "shoot" the radiator hose just above the thermostat housing, due to its matte surface; if you shoot the housing or intake, a more glossy surface can result in a less accurate IR reading.
