Replacement Battery - NCRS Discussion Boards
Replacement Battery
  • chris burbage #34073
    Replacement Battery
    What type and size battery originally came in a 65 Convertible 396 car? My first goal is not a repro but a good driver battery possibly the Sears battery that has the anti theft feature built in. Down the road I plan on getting a repro type battery for correctness but that is at least a couple of years off.
    Chris
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Replacement Battery
    Chris, I would get any Delco battery. All original batterys were AC Delco.(you will get points in judging if its a Delco, not Sears,(full deduction for non Delco)
    Texas Chapter NCRS
      Bob, I understand the dilemma. I don't plan on showing the car for awhile. My immediate goal is to do some cruising and enjoy the ride while I research and learn more about restoration. Down the road I'll bite the bullet and get into the resto. For now I was considering replacement of the battery with the Sears unit for security concerns more than anything else. I wanted to cross reference from the delco to the sears chart but I don't know the delco part number or type (size?) for the original.
      Chris
      • Bill Lucia
        Chris, I have a repro battery from restoration Battery for judging in my 66 BB coupe. It has the right date stamps etc. You can see their add in the Drive Line for the right unit for your car. For driving I use a Delco top post repalcement (fully sealed) that I got from my Chevy dealer. Chevy has one for your car listed as a Type 24-7. It is a 7 yr battery. I use the same one in my car and it fits perfectly. Cost is about $105. It still gets some points in judging as well. I only switch the repro in for Regionals and Nationals. I'd go with the Delco over Sears. My dealership had it in stock.
        Regards
        Bill #8620
          • 43240
          chris-----
          Battery size designations and nomenclature have changed since the mid-60s. However, you should be able to find the original size in your owner's manual. I believe that the current size for the battery you require is a "group 24". I may stand corrected on this, but that's my recollection.
            Thanks you all for the info. The reason I was looking at the Sears was that they have a battery that essentially doubles as a security device. I figured to use it as a driver battery and save the Delco for show use in the future. Does anyone have experience with the Sears Security battery? Gimmick or worth considering?
            Chris
            • Bill Lucia
              Joe, you're correct it's Group (or Type) 24 at Chevrolet for their Delco product. My 66 uses a Type24-7 Delco top post.
              regards
              Bill #8620
              • Tony H.
                • May 31, 1993
                • 537
                For what it's worth, I believe that some of the Sears batteries are (or at least were) made by Delco, namely, the Diehard series. I never got my car judged, though, with this Delco-made Diehard so I don't know what the points deduct is for the Delco-manufactured-for-Sears battery where a Delco battery was called for.
                Tony
                • Robert C.
                  • December 1, 1993
                  • 1153
                  Re: Security Battery???
                  Chris, So whats the security part of this Sears battery supposed to be?
                  Texas Chapter NCRS
                    Bob, The battery comes with a remote control similar to most alarm systems. When activated it decreases the available amps to only allow enough power to keep accessories energized (clock, etc.) but not enough to turn the mootor over. There are also some monitoring features. For instance if you leave your lights on it will, after some time, shut down all power when it reaches a critical state to preserve enough to start the car.
                    • Lou Lapham
                      Re: Replacement Battery,Delco's the one!
                      Chris-I echo what Bill L. said about the sealed Delco units.I have an earlier version called the Delco Permacell.It's got a 75 month warranty,550 cold cranking amps and it's been in my 66 air roadster since 1992 and it's never let me down,Bloomington 90's or Michigan 20's it starts.There is a Professional grade Delco now produced that is very similiar.AS an aside as far as i know Delco lost the Sears Diehard contract several years ago to another battery maker.By the way Delco has an exclusive cell design that probably helps them live so long. Lou
                      • Juliet P.
                        • June 30, 1999
                        • 349
                        Last time I checked (when they first came out) they didn't have rear terminal ones available at the local Sears. That might have changed, and you might not need a rear terminal style... but it's something to look into. They were also pretty pricey. ~$200. ~Juliet
                        Got a '70? Click here to Visit the Online 1970 Corvette Registry! E-mail me to join!
                        2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
                        1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
                        1965 Coupe (Greg's project No Flight)
                        Gone but not forgotten:
                        1987 Yellow Convertible 199k mi.
                        2002 Yellow Convertible 100k mi.
                        2007 Atomic Orange Coupe 140k mi. RIP flood 2015
                        2007 Lemans Blue 6-Spd Coupe 34k mi.
                          • 43240
                          Juliet-----
                          For info, side terminal batteries came into use on late 1969 Corvettes (after about s/n 22,000 or June, 1969). In fact, this was the first use of side terminal batteries in any GM car. For 1969, they were "front facing terminals", making them very difficult to access. For 1970, though, the orientation of the battery was reversed and the terminals became "rear facing terminals".
