72 Vacuum Tank - NCRS Discussion Boards
72 Vacuum Tank
  • Greg Sullivan
    72 Vacuum Tank
    Folks,
    My vacuum tank has a split in it(72 Vette). How much should I spend on a replacement? Should I buy used? Where do you recommened I buy a tank.
    Have a good week!!!
    Greg
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 72 Vacuum Tank
    Vacuum tanks are not easy to remove. Would some JB Weld seal the split? Some are really good with a wire welder.
    • Greg Sullivan
      Re: 72 Vacuum Tank
      Jim,
      The tank is already out. If I can't find a new replacement I may just weld it.
      Greg
        • 43240
        Re: 72 Vacuum Tank
        Greg-----
        I don't think that these tanks are currently reproduced. So, if you want a new one, you'll have to find an NOS example. These come up from time-to-time on eBay. You need to be sure to get a 3 port tank and not a 2 port, though. Expect to pay anywhere from $100-250 for one on eBay, depending upon how "hungry" and foolish the bidders at the time happen to be.
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: 72 Vacuum Tank
          Hi Greg,
          Depending on just where the split is, I think I would look at soldering it first. Far less warpage and metal degredation that way.
          I'd take it to a reputable radiator shop and see if they could perform the repair.
          Just my two pennies worth,
          Chuck
