C2 Screw Description, 9420684 ? - NCRS Discussion Boards
  • Alan Drake
    Know the 9420684 is a chrome philips but what head flavor?
    Re: C2 Screw Description, 9420684 ?
    Alan -
    They're cad/zinc-plated flat-head phillips screws.
    • Alan Drake
      Re: Thanks John and now the reason.
      These are the screws which hold the headlight bezel along the top side when in the open position. Mine were chrome pan heads and when lossing a point at judging time I mentioned it to other members(3) who all said they had the same screw and also lost points. My bezels have been on/off so many times I'll just use what the AIM calls for, I know a place can be found for those wrong screws.
      Thanks for info OH where did you get the screw book?
        That screw is described in the JG, in the Exterior section, under item #12, "Headlights". The incorrect pan head chrome phillips screws are frequently found in those locations; flat head screws were used originally so they didn't protrude into the gap and scratch the paint on the edge of the headlight opening when operating the buckets.
