Hello All:
I need some help interpreting the results of a cylinder leakdown test.
I have been performing various diagnostic tests on my engine to determine the cause of a poor idle condition. As you may have seen from an earlier posting, one thing I found is that my 300 HP engine has the 350 HP cam in it, which is not very compatible with my Powerglide transmission. It is possible that just a cam swap (which is now underway) will completely fix the problem.
I have also been looking at compression and leakdown. I read about the leakdown test on this board and decided to try it along with a conventional compression test. I purchased what appear to be decent compression and leakdown testers from Jegs, and ran the tests.
The compression test results look pretty good, ranging from 158 to 165 psi. The leakdown tests range from 20% to 30%. On the leakdown tester, the range of 0% to 40% is marked "low" and the range of 40% to 70% is marked "moderate." I'm not sure how the percentage is calibrated on a leakdown tester, so I don't know exactly what a result of 20% means other than it is reasonably good (at least according to this brand of tester). I wonder whether another brand of leakdown tester would yield different numbers for the same leakdown rate.
If I just looked at the compression and leakdown numbers I would conclude that things are in reasonably good shape. However, what bothers me is that on one cylinder that reads 158 psi compression and 30% leakdown, there is a very clear leak in the exhaust valve that I can hear and feel (the exhaust maifolds are off). On all the other cylinders there is no perceptible leakage in the intake or exhaust valves, with all the leakage appearing to be past the rings.
In the old days I would have simply run a compression test and would have concluded that things are okay. My problem is that I'm not sure how to interpret the leakdown test numbers. In particular, I am bothered by the perceptible leakage past one of the exhaust valves. Is this "normal" for a stock engine with maybe 40K miles on it, or does it clearly point to a need for a valve job?
Can some of you who have more experience with leakdown testing help me get calibrated on what is normal for a leakdown test and what is abnormal? Any help would be appreciated.
