327 Engine block w/o VIN - NCRS Discussion Boards
  • Chris J. Yates
    I have recently acquired a 327 engine block that has the correct code stamping for a 1964 Corvette, but does not have a VIN stamping.
    This block has not been decked, and the code stamping appears original.
    Block Casting: 3782870
    Cast date: B 1 4, Feb. 1st 1964
    Date code: F0213RT Flint / Feb. 13th / 365HP 4SPD T/I
    The block is standard bore and in excellent condition for it's age.
    My questions are: Was this installed as a warranty replacement engine?
    What possibles explanations are there for the lack of
    a VIN stamping?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    OTC...
    Over the counter purchase or warranty. As you might imagine, these blocks can be quite valuable to the right person...
    • Jerry S.
      • May 31, 2003
      • 145
      Re: replacement
      I've got mine and the car it belongs into. My car will not have a vin number stamped to the virgin block. Of course I have no courage to have a car judged.
      • Tom B.
        • March 1, 1978
        • 720
        Re: replacement
        I have a late June '61 270 horse engine like that. I took it out of a '55 Corvette in 1975. I always figured that it was an OTC engine too.
        Tom
          • 43234
          Re: OTC...
          Dennis----
          Yes. Blocks like this are like a "wild card"; they can "become original" for any one of a whole bunch of cars. Blocks with completely blank, original stamp pads can be a "wild card" for even more cars.
          • Lawrence S.
            • April 1, 1993
            • 802
            Re: OTC...
            I thought warranty blocks or over the counter blocks were CE coded?
            • Dennis C.
              • January 1, 1984
              • 2409
              Lawrence, You are right, but the CE did not...
              ...start until a year I am uncertain of... I would guess, some of those on this board have that date dialed in pretty close... Value of a CE cylinder case drops the value instantly - for those interested in certain types of endeavors.
              • Dick W.
                • 10483
                Re: OTC...
                I purchased several L/88 and LT-1 engines from the general over the years and none of them were CE stamped. They had the assembly info with no VIN
                Dick Whittington
