Fuel line installation - NCRS Discussion Boards
  • John Pelkofer Jr
    Hello, Is there any other way to install the fuel line from tank to pump on a
    1966 427 conv. other than lifting the body from the frame? I have corrosion
    under the battery box caused by battery acid and would like to replace the line
    instead of repairing the section. Thank you in advance for any and all advice.
    Re: Fuel line installation
    Check the archives... This has come up before with some saying 'yes' it can be done IF you're VERY clever on routing the line. Most say you really need to un-bolt the body from the frame and lift it 'just enough' (not a FULL body pull) to gain working room.
    • Kent K.
      • December 1, 1982
      • 1139
      And remember
      to use a fish tape pulled through the frame with the old line so you can pull the new one back through.
      Kent Keech
      Kent
      NCM Founder - Member #718
