C2 heater box - NCRS Discussion Boards
C2 heater box
  • Gary B.
    • February 1, 1997
    • 7024
    C2 heater box
    Can someone tell me what the large heater resistor does that attaches to the inner heater box on a '66? Is this resistor part of some circuit that controls the speed of the blower motor? Am I correct in thinking that it doesn't control the opening or closing of the entrance or exit doors inside the heater box. Those doors are manually controlled?
    Also, does anyone have a good technique for filling in or disguising a few deep scratches on the external heater box? Dye? Shoe polish? Paint? A bit of fiberglass resin w/ pigment added?
    Gary
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 heater box
    Gary,
    If you're talking about the 2 bare wire coils (with 3 terminals, I believe) mounted on an insulating card, and attached to the inside of the heater box via sheet metal screws, then those are the resistors for the blower motor speed control.
    A foolproof way to fix minor gouges in the composite heater box, is to sand and polish to match the surrounding surfaces. Deep gouges and/or repairs require fill with colored resin, available from such vendors as Corvette Image, Corvette Central, or Shermersheims. Uncolored resin can be tinted with carbon black.
    joe
    • Gary B.
      • February 1, 1997
      • 7024
      Thanks Joe; yes it's the coil wire resistor *NM*
