65 396 & early 66 427 - NCRS Discussion Boards
  • Mark S. Lovejoy
    Do all 65 396 engines and early 66 427 engines use the odd size 3/8" hex head valve cover bolts? (instead of the normal 7/16" hex) I always thought this was correct but can't remember for sure. Thanks.....
    • 43221
    Re: 65 396 & early 66 427
    Mark-----
    If any 3/8" across-the-flats bolts were used on L-78 and early L-72 engines, it's news to me.
    • Mark S. Lovejoy
      Joe,
      I had the same response.
      Cranky has posted it over on the VH board, hence the question.
      Thanks.
      • Bryan L.
        • June 30, 1998
        • 397
        Paragon has them, listed as 65-66 big block.
        BL
          • 43221
          Mark-----
          Yes, I see that he later posted that he "found em [sic]" at Paragon. The link provided shows the Paragon 1741K bolts. He says that although Paragon doesn't describe them, he's sure they are the correct ones. I'm pretty sure they're the correct ones, too. However, I've got news for him----the Paragon 1741K are NOT 3/8" across-the-flats (i.e. wrench size); they're 7/16" wrench size, just like all other big block valve cover bolts. The only thing "unique" about them is the "indented head" (i.e. "untrimmed") configuration. I believe that this feature was, as far as big blocks go, unique to the 65-E66 big block valve cover bolts. However, the same configuration was used on many (but NOT all) small block valve cover bolts right through 1982.
          • Robert Jorjorian
            I have news for Joe = Hanson (cranky) is absolutely correct in that the 1965 396 (all of them in 65) used a valve cover bolt with a 3/8" hex not a 7/16" hex with a common head logo being a four leaf clover.
              • 43221
              Robert------
              The Paragon 1741K which your buddy said he was absolutely sure were correct for 65-66 have 7/16" wrench size.
              • Dick W.
                • 10483
                Know that at least thru '66 VIN 1,2XX had the 3/8" recessed head bolts
                Dick Whittington
                  • 43221
                  Dick----
                  Like I mentioned, it's news to me. Do you know if any of the C2 era small blocks also used these 3/8" wrench surface bolts? I have never found a 1/4" bolt with a 3/8" wrench surface on a Corvette. However, that doesn't mean that none were used. Maybe I just didn't notice the wrench size when I removed or installed them.
                  • Dick W.
                    • 10483
                    Joe, I do not know about the small blocks. Most of the C-2 cars that I worked on had a big block, I guess that we only restored/detailed 2 small blocks, a '66 350 hp and a '67 base engine.
                    Dick Whittington
