C1 Window Trim - Flash Chrome - NCRS Discussion Boards
  • Mike Harpster
    I have got the windshield apart on my '62 and am considering polishing the upper and lower SS moldings. Are these moldings flash chromed?
    Mike
    #40,893
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Window Trim - Flash Chrome
    Yes,they are. All the stainless trim on C1 and C2 cars is flash chromed.
    Regards, John McGraw
    • Mike Harpster
      Thanks John! Glad I asked the question.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        Re: Flash Chrome
        Why is this an issue? What are you NOT supposed to do to them? Can they NOT be buffed out?
        Rich
          • 11644
          Re: Flash Chrome
          Rich,
          The flash chrome is quite thin. You can easily buff through it, and since the underlying stainless appears a different color ("yellower") than the chrome it will be noticed.
          Patrick
          • John M.
            • January 1, 1999
            • 1553
            Re: Flash Chrome
            Rich,
            You can buff them, but you stand the chance of buffing through the chrome layer which will leave a mottled appearance. The areas where the chrome still is will have a slight bluish cast to it while the areas where you buff through to the stainless will have a slight yellow cast to it. It is only really noticeable when it is mixed like this. I usually just strip the chrome off with muriatic acid prior to sanding and polishing. It takes a pretty critical eye to be able to discern the difference if recently polished. Polished stainless will turn a little more yellow as time goes on, but a little hand polishing every so often will keep it looking pretty good. I have had parts flash chromed again after polishing, but I usually will only do this on wheelcovers where they are more noticeable. I have Top Flighted many times with trim that was stripped and polished, and nobody ever made note of it during judging. It is a pretty subtle difference, and most people would never notice. Stainless that has been let oxidize for a long period of time will look real yellow, but it just takes a few minutes with chrome polish to bring it back. I suspect that the low maintenance of the chrome was the primary reason that GM flash chromed these pieces originaly. I have a C2 windshield molding that I buffed through the chrome in some places a couple of weeks ago, just to show someone the difference, and it looks like crap!
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              Re: Flash Chrome
              Thanks for the information and the excellent description. I did not know this.
              Rich
