Expansion Tank For My '56 - NCRS Discussion Boards
  • steve westphal
    I need an expansion tank for the radiator on my '56. Any suggestions? Thanks
  • Terry D.
    • May 31, 1987
    • 2691
    Re: Expansion Tank For My '56
    Don't believe there was a exspansion tank on a 56. First year for that was 61.
    • Mike M.
      • May 31, 1974
      • 8385
      agree with terry, there was not a seperate expansion tank used in 56 like the 6 cyl vettes and the sbc midyears. i suspect what you're seeking is the upper tank of the radiator that is soldered to the radiator core. try dewitt. mike
      • David B.
        • July 31, 2004
        • 330
        Steve,
        The previous responses probably answer your question. But, if you truly want to add an expansion tank I did temporarily put one on my '57. (I have since removed it as I found it was no longer needed after curing a temporary overheating problem.)
        But, when I had one, I got a generic plastic one from an auto parts store and painted it flat black and hid it under the fender near the battery area. The overflow line ran concealed under the fresh air hose, using the support clamp for the heater hoses. It worked well, and was not obtrusive, and gave added reassurance for tough hot weather, high traffic, driving conditions.
        Dave Banwarth
        Dave, 1969 427, 1957
        Previous: 1968 427, 1973 454
