A Hole in C - 1 - NCRS Discussion Boards
A Hole in C - 1
  • Jimmy J.
    • May 31, 1988
    • 304
    A Hole in C - 1
    I have a hole (about 3/8 inch) in the well below my antenna. Should it be there or did someone drill it for drainage? There is not a hole on the other side. Thanks in advance. Jimmy
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Antenna housing ground strap to body bolt... *NM*
    • Dennis C.
      • January 1, 1984
      • 2409
      Will take a chance and guess this hole...
      ...will be on all C1 bodies from 56-62 - radio equipped or not... DC
      • Jimmy J.
        • May 31, 1988
        • 304
        Dennis I took another look last night and
        there is a hole on each side in the deepest part of the wells at the back of the fenders. The radio ground wire is not the hole I am referring to. Thanks for your response. Jimmy
        • Dennis C.
          • January 1, 1984
          • 2409
          Jimmy, Have no knowledge of those hole/s... *NM*
            • May 31, 1974
            • 8388
            Re: Jimmy, Have no knowledge of those hole/s...
            when one places a dozen cans of tincture of hops, along with some ice, down in the holes, one needs a drain hole. all my c-1's have them. it was a roy- inspired dealer installed accessory. mikie
