1969 Radiator hoses; which ones? - NCRS Discussion Boards
  • Dave R.
    • October 8, 2007
    • 107
    I am almost finished replacing my heater core and I want to replace all of my hoses while I am at it. Looking through some of my catalogs it appears that the radiator hoses differ between a car with an aluminum radiator and one with the other style (not sure what that is right now). How can I check the type of radiator my car has? I want to make sure I order the correct hoses.
    • 43221
    Re: 1969 Radiator hoses; which ones?
    Dave-----
    The only 69's that used an aluminum radiator were the following:
    1) 300 hp with manual transmission;
    2) some L-46, especially early;
    3) L-88/ZL-1
    ALL other 1969's used a copper/brass radiator. However, different copper brass radiators (and, different hoses) were used for small blocks and big blocks.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12740
      Also keep in mind that when you have (or haven't) power steering you need a different hose...
      greetings,
      Rob.
      Rob.
      NCRS Software Developer
        • 43221
        Rob-----
        Not that I know of for any 1969. Radiator hoses are the same for all applications with or without power steering.
        • Dick W.
          • 10483
          Joe, I believe early on there were two hoses. One w/o and one w/PS. They were replaced with the current one everyone uses.
          Dick Whittington
            • 43221
            Dick----
            I just checked on this in case my memory had failed on this one (as it has in so many other cases). I can't find any record of there ever having been different part numbers for the radiator hose for any 1969 Corvette application with and without N-40.
            The upper hose for most 1969 427's, GM #331876, is a mid 70's replacement for the original hose, GM #3967433.
            The lower hose, GM #3947868, is the same part as originally used for all 1969 big blocks, except L-88/ZL-1
            • Dick W.
              • 10483
              Oops! My bad. I was thinking of '68
              Dick Whittington
              • Dick W.
                • 10483
                Dick Whittington
