C2 66 Differential Cover question - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    Is the 66 Corvette rear differential cover dated? Also is the cast part number 3871375? Mine is a March built car, the one on my car was replaced and need to find an original. Thanks sincerely Brian
    • 43221
    Re: C2 66 Differential Cover question
    Brian-----
    3871375 was the casting number used for the cover for all 1965-77 Corvettes. I believe these covers were dated. I am certain that later examples (68-77) were dated and I'm virtually certain that 65-67 were, too.
    • Brian K.
      • May 31, 2004
      • 358
      Thanks Joe, I'll start my search now
      • Gary B.
        • February 1, 1997
        • 7024
        66 Differential Cover question; some not dated
        Brian,
        The orginal differential cover on my July '66 build date car is NOT dated.
        Gary
          Re: 66 Differential Cover question; some not dated
          My May '67-assembled cover isn't dated either.
          • Rob A.
            • December 1, 1991
            • 2126
            My June '66 assembled small block cover is stamped AO 6 7 66...thought they all were dated and coded..guess not.
            • John S.
              • September 30, 1997
              • 263
              Rob,
              This looks like an assembly date for your differential: 3.70:1 positraction rear assembled on June 7, 1966. Please check the "cover" to see if there are any date codes.
              • Gary B.
                • February 1, 1997
                • 7024
                Diff. Cover vs. Diff. housing
                Rob,
                John is correct. The code you listed is what is stamped into the bottom flange of the differential housing. That stamping is not on the flange of the differential cover.
                Gary
                • Rob A.
                  • December 1, 1991
                  • 2126
                  Re: Diff. Cover vs. Diff. housing
                  Gary,
                  Sorry, my mistake, as you say this data is stamped on the housing flange.
