C1 steering box article - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    Hats off to John Hinckley on the detailed and well written article in the July '07 Corvette Enthusiast magazine! I waited for this to come out before rebuilding my '55 steering box and I'm glad I did. One question: what about filling the box with grease when the build is done? If so, what was used? I noted the liberal use of wheel bearing grease when assembling, but did not see mention of additional lube.
    Re: C1 steering box article
    Mike -
    The box was filled with the same EP chassis grease that was used to pre-lubricate all the gears and bearings during assembly.
    Next month's issue has a C1 front suspension rebuild.
    • Rex M.
      Infrequent User
      • January 1, 1987
      • 12
      Thanks again John for the steering box article. I needed that one. I'm also looking forward to the suspension article coming up. That's another one that I need. Rex Murray #10895
