MUNCIE TRANSMISSION QUESTION - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Can someone tell me the meaning of the following code which is stamped on the top at the rear of the main case, K142041.
    Thanks in Advance
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: MUNCIE TRANSMISSION QUESTION
    Here is some more info on the Muncie: main case PN 3851325, tailshaft PN3846429 and side cover PN 3831707.
    • Philip C.
      • December 1, 1984
      • 1117
      1964/1965 case the K# is probably pass car *NM*
      • Wayne M.
        • March 1, 1980
        • 6414
        Kansas City Chevelle ...
        If the assy. date (eg. P0106) is stamped onto the lower right corner of the shifter side cover machined flange on the maincase, it's a 1964 model, which sort of corresponds with the "429" tail extension. Probably on a car that was produced around mid-January '64, if production was at the same rate as in the 1965 model year. A good Chevelle site would be able to give you month-end '64 VINs.
