I can't seem to get my wiper door aligned. The end closest to the windshield sticks up too high, higher than the forward edge. There is no mechanical interference on the fender sides and the stop screw is a good 3/8" from bottoming out. It appears as if the entire assembly needs to be moved toward the windshield. I saw in the AIM a note indicating "shim as required". What does one use for shims? I assume they mean shim the oblong retainers/screws.
Thanks, Mark
Thanks, Mark
