Date code questions--rallys/tires/plug wires - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    Hi all,
    Hope everyone is having a great weekend.
    8" Rally wleel codes; I have one set that is: K12 2(valve stem)22 AZ. Is this Feb. 14, 1972?
    Next set is: K196 11(valve stem)22 AZ. I thought these were the original wheels from my 1970, but I can't figure out this code?
    Firestone Wide Oval (Super Sports F70-15) These have DOT cyu2 F21638. What are these; can the dot number be deciphered?
    Plug wires (braided) from my 1972 454: Delco-Packard TV-R Supression-7MM 1Q94 (followed by a green rectangle) The "script" is the same color green. Is the 1Q94 the date code?
    Thanks to all in advance,
    I'm off to the golf course,
    George
  • William C.
    • May 31, 1975
    • 6037
    Re: Date code questions--rallys/tires/plug wires
    SP wire date code is first quarter 1994 as you describe it. Neither that date nor the 7MM designation are original for your car.
    Bill Clupper #618
    • Chuck S.
      • April 1, 1992
      • 4668
      Wheels. No, February 22, 1972; this one won't be original to your car, but dates aren't judged if it's on the ground. The other wheel is a later replacement and should be mounted rather than used as judged spare: K (Kelsey)- 1 (Chevrolet) - 96 (1996?)...11 (November) XXX 22 (22nd).
