C1 Original Softop on my '62 ??? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Gents, ...archives didn't help.
    Been tearing into the softop today. Looks like it hasn't moved in 30-40 years. It sure seems like the original. I took many photos, then looked for the rear window date. The rear plastic window is heat sealed like the N.A. book says. I had to clean the stamped area to see what it says. Date is 1264. Is that Dec '64, or April 26, 61? Is this a replacement or original?
    Photo of the stamping is unclear so here's a description:
    "upside-down mountain" with 4 peaks, an arrow pointing down below it. Inside 2 letters "P" vert bar "C"(maybe "G").
    AS6 1264(heavier stamping)
    DO NOT RUB DRY
    WASH WITH WATER
    SOAKED CLOTH
    Links to photos:
    Rich
  • Dan A.
    • May 31, 1974
    • 1074
    Re: C1 Original Softop on my '62 ???
    The vinyl window appears as if it may be heat sealed on the outside. You'll have to tell us. If it is, it is not the one the General installed the day it was built. Sorry.
    • Mike E.
      • February 28, 1975
      • 5138
      Agree with Dan--that immediately stuck out to me! Replaced at some time in the past.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        Ok, Just by that datecode seems it was later to me too. And yes, the heat seal is on the outside. The hide-em end caps didn't look right either.
        Rich
        ps I guess I'll have to install a new top now!:-)
