C3 PO2 Wheel Covers again - NCRS Discussion Boards
  • Jim K.
    • August 31, 2000
    • 554
    Hey Terry: In an earlier post you had replied to me about the P01 (or P02) wheel covers and ballancing them if mixing and matching. How exactly is that accomplished? I'm thinking to balance a bare rim on the old bubble balance, then add the cap and balance again with washers or something (I'll hAVE TO CHECK THE BACKS FOR THOES CLIPS AGAIN) screwed onto the cover from the inside??? is there a better way???
    Jim
    "...if you mix and match pieces, you should rebalance them. They have small metal clips around the back edge the factory used for balancing purposes. They are heavy and they must effect balance of the wheel to some degree."
