C3: natural or cast finishes - NCRS Discussion Boards
  • Andreas Yanniotis
    Hello. I tried doing a search but did not come up with any answers. I know the judging manual says parts that are to be natural in finish can not have any clear on them, but then how are we supposed to protect/preserve them from rust, tarnish or deterioration. Is there anything I can use? without losing points?
    Thanx
  • Kent K.
    • December 1, 1982
    • 1139
    Re: C3: natural or cast finishes
    Back when I restored my 1967 in 1994, I used (probably too many coats of) a product called "Coricone". Non of the judges asked about the protective coating. It did not color or change the sheen on natrual cast iron or steel parts such as the coli springs, however, as the years passed, it has become somewhat yellowed or tannish, whichever your eye discerns. It may be removed with a laquer thinner dampened rag. Exactly what happened to the company or which product replaces Coricone, I have yet to discover. I have been told that there are products available that accomp[lish the same results.
    Kent #6201
    Kent
    NCM Founder - Member #718
    • Tom D.
      • September 30, 1981
      • 2134
      http://www.corrotherm.com/coricone.htm
      I found on the 'net.
      Tom D.
      4889
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Andreas Yanniotis
        Re: http://www.corrotherm.com/coricone.htm
        Thanx guys. I will investigate this.
          • 11643
          Other products would be CRC 350 and Pre-Lube 6.
          Patrick
          • Andreas Yanniotis
            Thanx Patrick
