Wire straps - NCRS Discussion Boards
Wire straps
  • Rainer S.
    • May 31, 2003
    • 468
    Wire straps
    Does anybody know the reason for the 2nd hole in the typical wire straps being used to hold the wire harness to the fenders ? I have never seen the 2nd hole being used...
    Rainer
  • Joe R.
    • March 1, 2002
    • 1356
    Re: Wire straps
    I have found the first hole to be a tight fit when the strap is used for the hose that goes between the small block expansion tank and the radiator. I use the second hole for these. I don't know if this is considered "incorrect."
    • Rainer S.
      • May 31, 2003
      • 468
      Re: Wire straps
      I think you are right, 2nd hole for large hoses, small for wires...
      rainer
