54 Born date - NCRS Discussion Boards
54 Born date
  • Jerry H.
    • April 22, 2007
    • 8
    54 Born date
    Could someone tell me the assembly date for a 54 Vin#E54S003234 and or where the information can be obtained.
  • Tom D.
    • September 30, 1981
    • 2134
    try C1Registry.com *NM*
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Willard M.
      • August 31, 1979
      • 422
      Re: 54 Born date
      My car is #3184 and has a June 30 birthdate if that helps.
      Bill #2659
      • Donald L.
        • September 30, 1998
        • 461
        Re: 54 Born date
        • John R.
          • September 30, 1999
          • 288
          Re: 54 Born date
          Jerry, your date comes up the same as my 54 (May 28), although I believe that the true date may actually be later in June. I would be interested in knowing your engine casting date and sequence number stamped on the pad.
          • Jerry P.
            • September 30, 1989
            • 85
            Re: 54 Born date
            July 1 1954
            • Jerry H.
              • April 22, 2007
              • 8
              Re: 54 Born date
              John, my number is 0643284 F4YG. I have a Pennant Blue car. What is your sequence number? My date on the C1 Registry comes up May 31. It is July 1 on the NCRS page.
              • Russ U.
                • April 1, 2004
                • 345
                Re: 54 Born date
                If you are using the NCRS website birthday calculator, you need to subtract 1000 from you serial number. That tidbit is in the fine print. If you don't subtract the 1000, the birthday calculator will add about a month on to your estimated build date.
                My 54 is #3279. Engine Serial Number of 0601431. Estimated build date is June 1, 1954. But I think it was a bit later than the estimate date. My car has only 42k miles and still has quite a few original parts. Several of the parts are dated June 1 or so. And the carb tags (original) are stamped in June.
                Russ
                • John R.
                  • 288
                  Re: 54 Born date
                  My car, number 3223, has a E174 casting date for its block and a 0390437 sequence number. The C1 registry shows the same birthday as yours, May 31, but I believe that it was a late June car based upon what I know about others that are close to my serial number.
