C1 327 engine pad stamping - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Hi, please help me.....can't find in the archives or in the spec guide.
    Questions about a 327(3782870) in a 1962 Corvette.
    -Is the assembly stamp and car serial number derivative in a single row, or in 2 rows, one above the other?
    -Approximately how much earlier would the block cast date be?
    Rich
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C1 327 engine pad stamping
    from outboard on the pad to inboard: vin derivative then the machine asswebly data. never seen an original where the vin/mach data was stamped on top of one another.cast date of case typically couple days to couple weeks prior to machine assembly data date. mike
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Re: C1 327 engine pad stamping & NCRS
      Thanks Mike. I thought so. My '59 has a '61 283 3756519 block in it and they're also as you described. I wasn't sure if the 327 was different or not.
      So while I'm thinking about it, I've never had my car judged at a regional. I've owned it 21 years(NCRS member about that long) and always used the NCRS spec as my bible(I won't even buy radial tires for it). I've been thinking about it. Should I consider it, even though it's not the original block? I feel a bit embarrassed asking but I really would like to know where the rest of the car stands.
      Rich
      • Wayne P.
        • August 31, 1975
        • 1025
        Have it judged. You can still do very well with a nom.
        • Verle R.
          • March 1, 1989
          • 1163
          Rich,
          I suggest you take it to a local chapter judging meet. It is a good way of getting the car judged and will give you a good indication of what to work on.
          Verle
          • Mike E.
            • February 28, 1975
            • 5138
            Don't be embarrassed!!!My first NCRS meet (1977) I took my first 62 (steel city gray with red shag carpet) through judging. Learned a LOT!!!!!! Helped me get to where I am today (one who has owned 28 62's, and still learns much about them every year)
            • Mike M.
              • May 31, 1974
              • 8389
              if you were a red head, you could use the shag carpet for yer thinning chrome dome. still owe ya for the 30 chev roadster pickup you were instramental in living at the Cumberland funny farm. mikie
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11323
                I ordered the 2 judging manuals. Here we go!
                Thanks Guys,
                Rich
