water pump bolts - NCRS Discussion Boards
water pump bolts
  • nancy charles
    water pump bolts
    on the 327/340 HP water pump, is there a bolt or stud & nut that goes on for the alternator bracket ? THANKS
    • 43221
    Re: water pump bolts
    nancy-----
    If you're talking about a 1963 340 hp, then I believe it was a stud and nut. If you're talking about a 1962 340 hp, I have no idea.
    • Philip C.
      • December 1, 1984
      • 1117
      Nancy 62 340 hp same as 63, nut and stud, like Joe and I and everybody knows hes a part number ________. Phil 8063
      • John D.
        • December 1, 1979
        • 5507
        Nancy, I just went to my garage and checked my freshly restored Feb 11th build FI engine and see that is has a TR bolt (unpainted) and split lock washer holding the alternator bracket to the water pump. The other three TR bolts are orange for sure. My mentor-Michael Hanson wrote in to me tonight and stated that it should be a bolt and NOT a stud. I am not 100% sure if this particular bolt and washer are plated or painted. But I am sure Michael will email me with the answer. 340 and 360 hp should be the same since they are identical engines except for the fuel system. John D.
        • John D.
          • December 1, 1979
          • 5507
          Nancy and others, Did you know that the 63 alternator brace (hockey stick) is unique to 63? It's much thinner than the later ones. Easy way to spot them is that there is a V stamped in the brace or bracket as you say. The V is very close to the slotted end. V is stamped at an angle. Hard item to find as they were very flimsy and easily bent. John D.
          • nancy charles
            john ; thanks for your response , my 1963 triple black roadster 327/340 hp has the bolt with a spilt washer . please let me know if it gets painted or not ? thanks NANCY
            • John D.
              • December 1, 1979
              • 5507
              Nancy, Do not paint the bolt and washer-split lock washer. Just leave it cad or zinc. The other three bolts that hold the pump on are painted for sure. Don't forget to put a lot of overspray on the bypass hose and clamps. Refer to the archives for nice pics of this hose from MH.
              Your triple black car sounds really nice. Mine is white on red.
              Our Pittsburgh chapter is hosting a regional in June 08 at Seven Springs ski resort in PA. We would love to have you and your car. Thanks, John
