stamped engine pad letters and # - NCRS Discussion Boards
  • Ray Armstrong
    I have an early 1968, dated Sept 1967, 427 block with the stamped letters and numbers II005IU on the engine pad. What do they mean?
  • David D.
    • 330
    IU is the code for a 427/435 L89 4speed *NM*
    • Philip C.
      • December 1, 1984
      • 1117
      Re: stamped engine pad letters and #
      Ray you have a L89 motor, 435 Hp with Aluminum heads the first I is a T. T= the engine plant 10= oct. 05= the fifth day IU= manual trans Aluminum heads. Does it have a vin number on it? Phil 8063
