C2 Transmission Decode - NCRS Discussion Boards
+ More Options
Posts
  • Randy R.
    • April 2, 2007
    • 39
    Hi,
    I would appreciate any help decoding these numbers off of a '63 roadster transmission. Thanks in advance.
    Housing number: 3831704
    Side Cover: 3831707
    Brass Tag bolted on side cover: 3831701
    Tail Shaft: 3831731
  • Harry Sadlock
    Re: C2 Transmission Decode
    Randy, I'd be happy to help, just to make it easy.
    Is it a BW T10 or a Munsey? Also, is there anything stamped on the underside between the main case and the tail?
    Harry
    • Randy R.
      • April 2, 2007
      • 39
      Harry,
      It is a Muncie transmission. I do not have any other numbers except for the ones listed.
      Randy
      • Harry Sadlock
        If I read everything correctly, 3831704 and 3831731 indicate an M21 close ratio for 1963. If you believe it original to the car the engine should be 340 or 360 hp. Also, a VIN derivative should be stamped into the bottom between the main case and tail. In the same location there should also be a set of numbers that follow the letter P that identify the build date.
        Harry
        • Harry Sadlock
          The 3831701 tag also says close ratio.
          I can't find the wide ratio trans numbers, but if the tag is original to the trans then I would tend to believe it is a real close ratio trans.
          Check for the other numbers punched into the trans as well as casting dates.
          Harry
          • Randy R.
            • April 2, 2007
            • 39
            Harry,
            Thanks for the help. The engine is a 327/340. I'll see if I can get more numbers and verify the build date.
            Randy
            • Randy R.
              • April 2, 2007
              • 39
              I got those numbers:
              0718 and 3120654 (matches the VIN)
              Can someone tell me the difference between the close ratio and real close ratio. I can't find the option code for it. Thanks.
              Randy
              • Harry Sadlock
                Randy, in 63 there was no option as I recall. You got a wide ration with 250 and 300hp and a close ratio with a 340 and 360hp. If you need the gearing I'll look that up later.
                I'm not sure what you mean when you ask for the difference between a real close ration and a close ratio???
                Harry
                • Randy R.
                  • April 2, 2007
                  • 39
                  Harry,
                  Thanks for all the help. I mis-interpreted one of you posts regarding the transmission.
                  Randy
                  • Harry Sadlock
                    Randy, if that trans in in your car, baby it. There will never be another original!!!
                    Good Luck
                    Harry
