accessory - NCRS Discussion Boards
accessory
+ More Options
Posts
  • Roy B.
    • February 1, 1975
    • 7044
    accessory
    Some have seen or know about my oil-eye. It's a after market item from the 50's so you don't need to stop the engine and open the hood to check the oil.I installed it under my dash and ran the line to the trans fluid, not the engine oil, it uses engine vacuum to suck the oil into the glass bulb . You run a line into the trans tube to a level so if the trans needs one quart of oil it will not fill up.
    You push the glass bulb button, it will light ( for night time) and the red trans oil will fill if the level is OK , after releasing the button the oil returns .
    You can also inspect to see if the trans oil is good by the color. This is the rarest after market item I've ever found and use daily before driving off. There are many neat things you can find now and then to make your Corvette different then others and you can use .But I know it's hard for you all being the NCRS loyalist you are!
  • Donald B.
    • May 31, 2004
    • 299
    Re: accessory
    I remember something like that on Sears/Craftsman lawnmowers in the early 60s. You pushed on a rubber bell shaped bulb and if the oil level was sufficient, a small amount of oil got sucked up into a clear tube. Gravity would then return the oil to the crankcase when you released the bulb.
    Never say or heard of anything like it for cars.
    • Frank C.
      • January 1, 1986
      • 277
      Re: accessory *NM*
      • Mike Barnard Sr No 36249
        Re: accessory
        Roy
        That's the best one yet in my opinion. I have never seen or heard of it. But it sure would come in handy on long trips or fowl weather.
