Original 1967 Corvette /GM Keys - NCRS Discussion Boards
  • Kirk McHugh
    Quick question. For an original 1967 corvette with a spare tire lock, how many keys should you have? Am I correct that it would be three, an A (ignition) B (doors), & C (glovebox/trunk lock) key? If so, could someone post exactly what they look like. I'm not sure one of the keys I got with my car is original and would like to compare them. Thanks.
  • Richard B.
    • March 1, 1989
    • 99
    Re: Original 1967 Corvette /GM Keys
    you should have two keys. one for the ignition (A) and one for the door locks, glove box, and the spair tire (B)
      • 43205
      Kirk and Keith-----
      Often, what happens is that a door lock, glove box lock, or spare tire lock gets replaced without re-coding for the original key. Then, you end up with 3 (or, even, more) keys to fit all the locks.
      • Richard B.
        • March 1, 1989
        • 99
        Joe,
        I realize that but he asked how many keys originally came with a 67. And I know for a fact that it is two.
          • 43205
          Keith-----
          I know for a fact that it's two, also. However, Kirk might not understand why he has 3 keys. That's why I responded as I did.
          • Peter L.
            • May 31, 1983
            • 1930
            Kirk - Slow answer. Actually the number is 4 because the owner received 2 sets of 2 keys, i.e., 2 "A" keyway keys and 2 "B" keyway keys. The original 67 ignition/door lock keys had the "A" keyway, octagon head key with the GM/Briggs & Stratton logo and the glovebox/spare tire lock keys had the "B" keyway, round head key with the GM/Briggs & Stratton logo.
            I think someone posted a photo recently, so you might check the archives and if not someone will surely post one shortly.
            Pete
            • Jeff S.
              • July 31, 1984
              • 383
              Kirk
              GM when to 'A' keyway (ignition, octagon) keyway on all models, '67 model year. Trunk, glove box, other stuff (oval) was 'B' keyway. For '68, C & D, etc. This was done as an anti-theft provision, since the (unstamped) keyways on '66 and earlier all shared a common keyway.
