65 brake caliper bolts - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    can you buy the correct bolts that hold the two caliper halves together, i think the company that rebuilt my calipers changed them out ,if i had to do again i would have told them not to change them out ,i would call and ask them , and still might but it was about three years ago, as i was looking at my front suspention the other day checking for correct bolts and noticed them ,i gust never thought they would change out those bolts. jim
    JR
    • 43236
    Re: 65 brake caliper bolts
    Jim-----
    The special, locking bolts used for 65-E67 caliper half fastening were called PLACE BOLTS. They are no longer available from GM in the sizes required for the caliper halves.
    However, the bolts are still manufactured and available. The primary manufacturing source is a company called Aetna Screw (www.aetnascrew.com). The problem is I don't know if they will sell you the bolts in the kind of quantity that you're looking for. That's often a problem with specialty fastners----you can only get them if your willing to purchase 100, 500, or 1,000.
    Caliper rebuilders often replace the bolts as a matter of standard practice and the replacement bolts they use are virtually never place bolts. In fact, their product liability insurance might require them to use new bolts. One other thing that you can do is to call the rebuilder and tell them your problem. They'll probably have some of the used bolts around and can send them to you. That will get around their product liablility issue, too, since they aren't the ones that will be installing the used bolts in the calipers.
    • Jim R.
      • June 30, 2001
      • 643
      Thanks alot joe. i will try that.
      JR
