Head gasket sealer/dressing on 3830711? - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    It appears the 3830711 GM head gasket comes with some type of silver coating applied. Is it recommended to install dry (as-is) or with additional high temp alum spray paint or other dressing?
    Yep...this is a steel head 4.020 bore application.
    • 43236
    Re: Head gasket sealer/dressing on 3830711?
    Jim-----
    Actually, I think the shim gaskets (like the 3830711) that are pre-coated don't really need to be otherwise coated prior to installation. Also, I never saw any evidence that the shim type gaskets I removed from engines had any factory-applied sealant. However, when I used to use the shim-type gaskets, I always otherwise coated them, anyway. I used spray-on Copper Coat. It's still available.
    • Jim V.
      • November 1, 1991
      • 587
      Thnks Joe....
      I suppose it can add a little more sealing protection....My deck heights are off .009 from side to side...so...I will be using a 3830711 on the short side and a FP1094 on the tall side. This should even up the SCR and quench.
        • 43236
        Re: Thnks Joe....
        Jim-----
        Use no sealer, at all, on the side with the composition gasket.
