Small Block engine # Is it a 283, 327 ?? - NCRS Discussion Boards
  • George C.
    • December 1, 1988
    • 583
    Is this number on block in front of pass head a good number ? Is it a Corvette Block ? 0121186F56F Thanks for your help.>George
  • William C.
    • May 31, 1975
    • 6037
    Re: Small Block engine # Is it a 283, 327 ??
    What is the casting number on the behhlousing flange at the rear of the engine? (drivers side)
    Bill Clupper #618
    • George C.
      • December 1, 1988
      • 583
      Bill, A friend just gave me these numbers. He's going tomorrow to look the car over. I'll try and get the casting # from him. I was looking at the codes in the NCRS spec guide and I can't find anything. Thanks for fast reply.>George
      • George C.
        • December 1, 1988
        • 583
        Just talked to him again. He's going to try and go later this afternoon.>George
        • Fenwick B.
          • January 1, 2005
          • 115
          According to the "1953-1967 Corvette Buyer's Guide", all of the 1956 Motors were 265's. The engine numbers ended in FK, GV,FG,GR AND GU. The G* blocks were 3 speeds, and the F* were Powerglides. The block that you have is probably a passenger car block.
          • Jimmy J.
            • May 31, 1988
            • 304
            This web site might be helpful
            Small Block Chevy engine identification. Code identification, Casting Number info.
            • George C.
              • December 1, 1988
              • 583
              Hi Fenwick, Thanks for your input. Still waiting to hear from my friend on casting number.>George
              • Robert Willis
                1956 Chevrolet 265 cu. in. 2 barrel passenger car engine, Flint Engine.
                • George C.
                  • December 1, 1988
                  • 583
                  Robert, Thanks you !. Will post the casting number when I get it.>George
                    • 43221
                    Robert-----
                    The "F" suffix code was also used for some 1957 283 cid engines in passenger cars and light trucks, too. The thing I don't understand is why there appears to be a VIN derivative on the pad. I didn't think that any Chevrolet cars had the VIN derivative stamping as early as 1957.
                      • 43221
                      George-----
                      Very likely it will be "3720991" if it's a 1956 265 and "3731548" if it's a 1957 283.
                        Don't think it's a VIN derivative, Joe...
                        From the '56-57 JG:
                        "1956 engines were serial numbered in sequence starting with 0001001...."
                        • Robert Willis
                          1955 "F" 265 cu in , 2 barrel, pg trans. block casting "524"
                          1956 "F" 265 cu in , 2 barrel, pg trans. block casting "991"
                          1957 "F" 265 cu in , 2 barrel, pg trans. block casting "548"
                          Pass Car Engines . I was into 55s awhile back.
                          Bob
                          • Philip C.
                            • December 1, 1984
                            • 1117
                            A little knowledge is a dangerous thing *NM*
                            • John N.
                              • February 1, 1975
                              • 451
                              Early Flint 56 265 for pass car with 2 bbl powerglide. Curious as to cast date.
