72 chaulk marks? - NCRS Discussion Boards
72 chaulk marks?
+ More Options
Posts
  • Denny J.
    • November 1, 2000
    • 244
    72 chaulk marks?
    Does anybody have a check list for chaulk marks.Or where would I send them with photos is there a central location or person?
  • Denny J.
    • November 1, 2000
    • 244
    Re: 72 chaulk marks?
    OK under the steering wheel shaft on the fire wall.I need to get this car up in the air.
    • Chuck S.
      • April 1, 1992
      • 4668
      Left lower firewall may have script crayon marks PB (power brakes) if so equipped.
      • Chuck S.
        • April 1, 1992
        • 4668
        I should have added that these marks are not normally visible; they are behind the sheet metal splash shield that is attached to the lower firewall.
        • Denny J.
          • November 1, 2000
          • 244
          Nope changing oil look up and under the sreering shaft side ways PB on the fire wall.Sideways goofed me up and does not look like a PB But you were 100% right.PB Denny
          • Chuck S.
            • April 1, 1992
            • 4668
            In the same area on the right side, your car may have the build number that was assigned before the car started assembly in the body shop. This number will probably be a three digit number between 001 and 499 or 999. It was used to identify which body components (coupe or convertible) were used, and which options were installed on the assembly line.
            You may also find this build number, or a shortened two digit version, marked on other areas of the car (front RH wheel well, luggage stop partition, rear compartment bulkhead in front of fuel tank). In the front of the right front wheel well, a two digit number was used...i.e. if the build number were, say, 426, the wheel well would have only the last two digits, or 26.
            Only the firewall marks may be visible without considerable disassembly, which you want to avoid...the other build numbers are covered by blackout paint, carpet, or the gas tank.
