I'm changing over to what I think is the correct pulley setup for a 327/300 with power steering ( no air). Attached is a picture of the cast iron pulley I removed from the car.
Can anyone tell me what setup (if any) this pulley would be correct for.
Here's a couple of clues.
1) it bolted up nicely to the harmonic balancer with 3 correct looking bolts
2) there is a raised lip on the back that fits perfectly into the hole in the center of the balancer
3) ACME 04296 and 4060-6SP-64051
4) the center hole has an ID of about 7/8 of an inch. The harmonic balancer bolt I removed was about 4 1/2 inches long. I don't think my crank should be drilled for a bolt but its there
5) It is a 2 grove pulley
