C1 Trunk Lock - NCRS Discussion Boards
C1 Trunk Lock
  • Mark Radin
    C1 Trunk Lock
    I just noticed the lock and bezel on the '59 I am working on is not recessed into the panel. Does this mean the trunk is not orginal, or has it just been modified?
    Mark
  • Brad K.
    • August 31, 1990
    • 414
    Re: C1 Trunk Lock
    If what you are saying is......The lock assembly face, when it is in place is NOT almost 90 degrees to the ground (as it should be) then what you say is true. The trunk lid is an aftermarket one and not original. If the lock assembly face follows the contour of the trunk lid and faces up into the air then you've got an aftermarket as well. I'd then say that you'd better be looking for a different trunk lid, which can be found on e-bay
    This MAY be the reason why you've asked the next question about the trunk lid being slightly off-center
