C - 1 245 HP Fast Idle RPM - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    What is the correct fast idle RPM for a C - 1 245 HP? Thanks, Jimmy
  • Jack H.
    • April 1, 1990
    • 9906
    Re: C - 1 245 HP Fast Idle RPM
    From the 53-62 Corvette Operations Manual & PV Test Guide:
    "On all but six-cylinder manual choke engines, full, fast idle speed is specified to be set at 1700 to 1800 RPM on a FULLY WARM engine."
    That means when you cold start the engine, initial idle will be lower (could be as much as 50% depending on ambient temp) and the speed should increase as the engine warms converging to the 1700-1800 RPM range if the accelerator isn't touched to let the choke's high idle collapse...
    • Jimmy J.
      • May 31, 1988
      • 304
      Thanks Jack I kenw it was written somewhere but I couldn't find it.
