C2 dash cluster labels - NCRS Discussion Boards
  • Tim Sargent
    Is there any de-coding of the red and white label on the back of the C2 dash cluster? I have a 67 L-68 with a "LC" code the dash is dated Oct 12 1966.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2 dash cluster labels
    Yes. The designation changes depending which Tach,speed warning option, and oil pressure gauge are used. "LC" is correct for your car.(NO SPEED WARNING)
    I don't know the codes for the others.... saw different codes but didn't pay attention.
    • Rick S.
      • January 1, 2003
      • 1203
      I also have the "LC" tag, date stamp of May 18.1967. The car is a L79 with no speed warning.
      • Mark S. Lovejoy
        LB, '65 L78 (396, 425).
        • Tim Sargent
          The L-79 and L-68 would be the same dash i.e., 6K redline and 60 lb oil pressure gauge as long as neither has Speed Warning
          Thank
          Tim
          • Mike E.
            • February 28, 1975
            • 5139
            67 base motor with speedminder is LA in green print
            • Jack W.
              • August 31, 2000
              • 358
              Re: C2 dash cluster labels - '65 L78 & L76
              isn't the 65 396 (L78) dash configuration the same as the 65 365 (L76)?
              and thus, wouldn't the same cluster broadcast code (that's what these two-alpha stickers are, in effect) be used for that 6500 redline, 80 lb oil pressure gauge cluster in 65?
              • Tim Sargent
                Does anyone have a complete list of dash configurations and codes?
                Thanks Tim
                • Kent K.
                  • December 1, 1982
                  • 1139
                  Mike,
                  Our Corvettes are very similar with three exceptions. IMSMC, your car is automatic, has speedminder and is originally from California. Mine is from Texas, is base engine, 4-speed with A/C and has a LA label in red print which to the right reads:
                  CLUSTER 6457982
                  SPEEDO 6455367-W
                  TACH. 6412222-W
                  AC--MADE IN U.S.A.
                  Happy Easter,
                  Kent #6201
                  Kent
                  NCM Founder - Member #718
                    '67 base engine, no speedminder - "LA" in red.
                    • Richard S.
                      • November 1, 1994
                      • 809
                      Tim,
                      I think several members do have complete listings......hopefully someone will post. You should also search the archives as this subject has been posted several times before.
