1965 Roadster vin 194675G104349 - NCRS Discussion Boards
  • tim divi
    Hi All,
    I am new to all this so please bear with me. I have a 65 convertible and a 2006 coup. The 65 is my baby but needs alot of work,It runs good and is pretty tight but needs work. This ca was in an accident somewhere back in the late 60's as my brother in law has owned it since 70 and has done nothing too it. It has a 67 front end on it and not the original engine. I was told this was a big block car. Is there any way to tell? The tach redlines at 6500 and I have read this may mean it was a big block. any help for this amature would be appreciated.
    Tim
  • Jerry S.
    • May 31, 2003
    • 145
    Re: 1965 Roadster vin 194675G104349
    We just bought a real nice 63 convertible with nice looking 65 engine, low HP, if you need one. The car will be delivered to me this week. Just love those BJ auctions.
    • tim divi
      Hi,
      Thanks for the response. I will definetly keep in mind. I am located in central Jersey. Any idea how I can tell if this was a big block car?
      • Mark L.
        • 561
        Tim, Check the archives. There have been many previous discussions on this subject. Also you have a great opportunity to attend the Edison NJ Regional Meet in May and learn alot more about your 65. Good luck.
        • tim divi
          Hi Mark,
          I will Look at the archives, I am just learning to navigate the site. Thank you for your response and I am looking forward to learning all about the car. I will also look into the meet.
          Thanks again,
          Tim
          • Loren L.
            • April 30, 1976
            • 4104
            Simplicity - is the battery on the driver's
            side? Does it have a rear sway bar? If the answer to those 2 questions is "Yes" then it MIGHT have been a 396 and you should chase the archives, buy a 1965 Judging Manual and start highlighting. Good luck.
            • Page C.
              • February 1, 1979
              • 802
              Vin Number To Early for Big Block
              From the vin number your car was built in late Nov or early Dec of 1964. The earlest big blocks were around March of 1965. If yours has the 6500 tack and 80lb oil gauge, it was probably a 327/365hp.
              Hope this helps.
              Page Campbell
              • Loren L.
                • April 30, 1976
                • 4104
                Ever seen 194675S100003? *NM*
                • Page C.
                  • February 1, 1979
                  • 802
                  #003 small block car converted at factory *NM*
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    I believe that it might well have started life
                    as a '64; it received handlaid/created gills in the front fenders to take on the '65 style fenders. I believe my memory is correct that No other emblem holes were found in the fenders other than the holes that its handmade brass emblems that read something like:
                    "427 Turbojet
                    Mark IV"
                    I know that the owner told me 25 years ago that whenever the car goes anywhere, only one fender emblem is on the car - if somehow manages to steal that one, the other can serve as a model.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      '81 Nat'ls, St.Louis -- Installed only for Photos
                      then removed for safekeeping. I believe used same holes as FI side emblems.
                      • Drew P.
                        • June 30, 1977
                        • 180
                        Hello Tim
                        The VIN you have posted has a error. The letter " G " should be a " S " .
                        Double check the plate under the glove box. Hopefully there is a " S ". If not you have a BIG PROBLEM now.
                        Drew Papsun
