Help identify C2 distributor cover... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hi, I don't know mid-year stuff very well at all. I have a mid-year stainless distributor shield (rather nice I might add ). I want to figure out what year it belongs on. It appears to have come off a FI car because it has a two possition clip (cad plated spring steel) on the front that is in the FI postion. It also has a ground clip on the back side which is chrome plated. It has two plastic rivets on the top to hold the insulator sheet in place. Any, chance this is enough information to identify it?? I am thinking 1965 or 1964?? Thanks, Terry
  • Bill S.
    • January 31, 2007
    • 396
    Re: Help identify C2 distributor cover...
    search around jan i did a ton of correspondence on this. there was a good drawing on 2 types as well posted. many had FI but this refered to where to put the ground clip.
    • Terry F.
      • 2061
      Thanks, Terry *NM*
      • Terry F.
        • 2061
        I read that thread. Mine looks like the one in that auction but my grounding tabs are all there. Any chance I could send you some pictures of it when I get a chance. If possible, email me at tfringo@aol.com and when I get off work I will try to send some picture of it and the supports. I would like to identify it if possible. I think it is a pretty nice original item. Definitely stainless. Take care, Terry
        • Bill S.
          • January 31, 2007
          • 396
          look in the paragon catalog, that is a great way to id parts as the have more pictures with years id'd than others.
          • Terry F.
            • 2061
            I don't have a C2 catalog from them. Should get one for the heck of it...
            • Alan Drake
              Great article in Restorer - "1963-67 Corvette 327 Engine Radio Ignition Shielding Wire Shields & Routing Supports" by John Amgwert. Do not know what Vol or Year, I found on the 63/64 CD edition. Also look at Nolands Adam book, has some drawings.
              To determine what year you have many details will be needed and even after verifying all of them you may still be confused, as I still am.
              • Terry F.
                • 2061
                Thanks, Terry
                • Rob A.
                  • December 1, 1991
                  • 2126
                  I have some good info on these...if you email me a pic of it, I can tell you what year(s) it is from.
                  • Bill S.
                    • January 31, 2007
                    • 396
                    you can down load a catalog fro paragon. i am really happy with them. bill
