Rust on Engine Pad. - NCRS Discussion Boards
Rust on Engine Pad.
  • Frank O.
    • January 1, 1997
    • 19
    Rust on Engine Pad.
    I have a problem with rust developing on the engine pad of my '71 roadster. In the past, I have always put a thin coat of oil on the pad. However, I neglected to take of care of it recently. I now have a fair amount of rust buildup on the pad. I can still see the numbers but I don't know how to remove the rust safely without compromising the integrity of the numbers and broach marks. Can anyone suggest an answer to this problem? Thanks
    • 15676
    Re: Rust on Engine Pad.
    Try a Scotchbrite pad and toothbrush wetted with mineral spirits or paint thinner.
    Once it's clean keep a film of WD-40 on the pad. Motor oil will collect dirt.
    • Rob A.
      • December 1, 1991
      • 2126
      Frank,
      Eagle brand "etching forumula" mag wheel cleaner will remove the rust with no effect on the originality of the broach marks. Oil it afterwards, as you previously did.
      • Rob Dame
        CLR will clean it too
        • Gary Schisler
          Duke & Frank,
          I will disagree with the use of the Scotchbrite pad. The broach marks may be faint enough that a ScotchBrite pad may be too aggressive and result in unwanted scrathces that obliterate the marks. I would start with Simple Green and a rag. Starting with the least aggressive technique and go up from there. Once you wind up with a clean pad, use PreLube 6 from Quanta Products to keep your pad clean.
          Gary
          • Edward Boyd
            Try Corrosion-X. Put it on the pad for a few days and you will be able to wipe the surface rust off with a rag leaving the markings untouched. The Corrosion-X will get underneath the rust while penetrating into the metal to form a protective barrier. Use this and your problem will be gone.
            • Jim R.
              • June 30, 2001
              • 643
              No kidding try the works toilet bowl cleaner it will remove the rust and wont harm anything else ,put some on a rag and rub it , then why not clear coat it untill you show your car, and then remove the clear with thinner, if you dont want to spray the clear ,spray a little in the cap and use a Q tip and apply it that way.
              JR
