1990 Corvette Coupe - NCRS Discussion Boards
1990 Corvette Coupe
  • Cliff Weber
    1990 Corvette Coupe
    My recent purchase 1990 Corvette Coupe has 41xxx miles on it. Only will use for cruises and weekend fun. I took the car to a Chevy Dealer because the check guages light, seat belt light, low oil pressure light and air bag lights stayed on. Dealer said the DERM-air bag control module was bad, but GM has no replacement and that this was the only year for this type of sensor. Also said could not use one from another car since each one is programmed to a specific car. Does not know if air bag will work.
    Check guage light stays on because someone replaced oil pan with an aftermarket one that has no hole for the low oil pressure sensor. Dealer said that the seat belt light was also on this same circuit. Any help world be appreciated since I do want to keep the car as original as possible. Thanks Cliff.
    • 15601
    • George D.
      • August 31, 2000
      • 225
      Re: 1990 Corvette Coupe
      I don't know about the low oil pressure light issue, but I had a similiar problem with the air bag light on my 1990. The problem was corrosion on the connector under the dash on the passenger side. Once the corrosion was removed and reconnected the problem was resolved. I believe here is a proceedure to clear the codes for the air bag, but I don't recall what it was. I suggest you get a set of manuals for the car. They are usually available on e-bay.
      George
      • Jim T.
        • March 1, 1993
        • 5351
        Oil pan could of been replaced because someone stripped the threads in the pan for the drain plug. A used pan could be available from www.contempoarycorvettes.com.
          • 43221
          Cliff-----
          1) I don't know which module is the problem; there are two SIR-related modules for your application. The first is GM #10094618. This one is GM-discontinued but available in remanufactured form from Auto ECM's (www.autoecms.com). The other one, which I believe is within the steering wheel cavity is GM #10104008. I don't know where you'd find that one.
          2) 1990 Corvettes did not use an oil level sensor in the pan. So, not finding one is the condition that one should expect;
          3) I'll repeat advice I give often: if you're going to do any work, at all, on a Corvette, you MUST have the factory service manual. By "factory" I mean the manual prepared by GM and published by Helm, Inc.
            • 15601
            Oops
            Well this should again teach me to jump in where I know nothing. Cliff did say hole in the pan for low oil PRESSURE sensor. I read that too quickly without sufficient comprehension. Sorry -- I'll sit down and watch for a while
            • Cliff Weber
              Thanks George I just got the car and will be getting all the manuals for sure. Hopefully it is a corrosion issue. Thanks Cliff
              • Cliff Weber
                Re: Oops
                Appreciate your quick response and I always make it a priority to get all the factory manuals. Thanks Cliff
