C-3 Rear End Numbers - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 976
    LR W 063 E 2
    Help in decoding this please.
    Too new for me.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C-3 Rear End Numbers
    Jimmy
    LR is 3:36:1 in my books
    Lyle
    Lyle
      • 43221
      Jimmy-----
      "LR"= 1971 to 77 3.36:1 positraction (all 1970+ were positraction)
      W= Warren Gear and Axle Plant
      063= 63rd day of the year
      E= Eaton Positraction unit
      2= 2nd shift
        • 43221
        Addendum
        Jimmy-----
        While the year is not coded into the stamping, it can be determined by observing the casting date found on the carrier case. The last digit of that sequence represents the last digit of the year. While the same casting was used for more than 10 years (i.e. so there are "repeats" of some "years"), the stamped coding was different for those "repeat" years, so the actual year can be easily discerned. Some of the later cases may even have had some 2 digit year codes; I don't recall, for sure.
