Terry 72? - NCRS Discussion Boards
Terry 72?
  • Denny J.
    • November 1, 2000
    • 244
    Terry 72?
    Dates on window are As-2 LY dot 15 M74 the other is same but JY.The papers in my book said the drivers side was replaced. dates OK?Pulled spaire tire down it has a paper tag that was molded into the rubber
    #?458 also MJU2 DXA 192 what are the #s for? Wheel weight "not micro"
    it is 1/2 14 1/2 there is a circle around the 14 original? AIR filter JM said 212 cw or 329 cw ther is no way this will fit.On the side of cleaner it has a paper tag AC 329c it is 1/3 of the size.Passenger wheel well in the front has chalk marks in the sign of a "T" any help?Spark plugs wires are Packard TV 20-72.Water pump will be here Wed. Bill said Hi.He will not be here in june.As you know I had the trim rings buffed still a little hazy but much shinnier I like 'm.Bad ? or go looking at swap show and look for used. on or off line?
    Either way I want to say I'm sorry for my actions the other day! Sorry.
    • 15601
    • Denny J.
      • November 1, 2000
      • 244
      Re: Terry 72?
      Two weeks of hell@#$ WHY Thanks for hanging in there for me.I did have a great day sunday with my car,water pump is out,New one from Bill will be here wed steering wheel is a part waiting for lock smith,My friends call it the Jesus clip,Jesus put the clip in and hurry.Rear shocks are on, looking for CRC 350 The amount of rust is so little lots of black paint.Next is starter and front shocks.Should I check all plug wires for 2Q-72 when you said "right Bill" is there something I should watch out for ? fire? next update Tue.Ah window date is ok.thanks!! Trim rins salavi.Chalk marksThis car has more than I can photo Almost like a street gang tag team.Do you have a spreed sheet to fill in the blanks?
        • 15601
        • Denny J.
          • November 1, 2000
          • 244
          Re: Terry 72?
          Tue up date Parts came in, Drivers door plastic clip door guard .Go ahead and try to find one of thoes.Battery Restoration and battery shut off switch and fire extinguisher drivers door weather strip,And seat shims in bag,Now your going to talk about the weather strip all ready done sorry But hold on.On the driver side I cut the first 3" off in nov show Ray Wolson gave me a nock for missing so I bought just the drivers door just for the first 4" and spliced it in cant till but for age.Here is a trick on the glue mix yellow and black and it will come close in age look. NOW frame In nov the person who look under my car needs an eye pluck There is more black paint than rustXXX AGE dont like the word rust.Most of the age is under doors rails from the tires kicking up.No work wed next update thur {water pump}Denny Can I Ask?
          Does my name have a special flag! keep an eye on him lots read me.
            • 15601
            Re: Terry 72?
            You don't need the plastic door protector(s), in most cases it was removed during normal dealer new car prep, so most judges are not looking for it. I have a box full of them in the garage (none for sale). I hope you got the white ones, and not the black ones.
            If most of the paint is there on the frame (one hopes not on the fiberglass), I hope you cleaned it carefully.
            Your first post got a lot of reads because there are lots of Terrys posting here -- I think I counted five in the profiles section. More than I would have expected. So many that at times it is confusing figuring out who is referred to.
            That said, this is a public forum and anyone can read what is posted.
