Clutch Head bolts on a 58 - NCRS Discussion Boards
  • Steven B.
    • June 30, 2004
    • 256
    Around my entire 58, I've only found 6 clutch head bolts holding the hinge and the door of the seat separator, but believe there may originally have been more used around the car. Where should others be found around the car, and were they actually found securing the hinge and seat separator door in place?
    thanks in advance, Steve
  • Gary C.
    Administrator
    • October 1, 1982
    • 17693
    Re: Clutch Head bolts on a 58
    Steve, recommend getting the '58 Judges Manual from the NCRS store, which will tell you how many clutch heads were used in the seat separator and other locations such as in the trunk. Good luck, Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Chris H.
      • April 30, 1990
      • 817
      Inmy 62 they also held on the headlamp cups and splash shields I believe.
      • Steven B.
        • June 30, 2004
        • 256
        Re: Clutch Head bolts on a 58--thanks guys...
        thanks guys. I actually went to the Paragon parts book and put in clutch head and looked at all the locations that they sell them for---should have done that before posting the question--but came up with the hood support to the hood ledge, the hood release cable, front splash shields, the headlamp housing to the fender, the horn contact, the lower fan shroud, and the seat separator catch and hinges. Hopes this helps others.
