engine rotation question - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    i know alot of you will think this is stupid but i have to ask. looking at the engine from the front of car, does the engine turn clock wise? i am very rusty and tired. after i wired the car i bumped the starter and the timing line went to the right (clock wise) for some reason i expected it to go the other way so i thought i would ask. also it the timing plate painted? it is very hard to read
  • Roy B.
    • February 1, 1975
    • 7044
    Re: engine rotation question
    turn clock wise Noooooooooooooo other WAY!
      • 15694
      Viewed from the front, clockwise is correct. You can verify by looking at the "advance" side of the timing tab.
      • Mike B.
        • November 1, 2004
        • 389
        The tab is painted along with the rest of the engine. But years of grime and coats of paint can obliterate the timing marks. Get a white crayon and wipe it on the tab to give your eyes half a chance of seeing the marks!
        • Bob Simard
          Don't bump the engine to move the timing mark.
          Just put the trans in fourth (assuming a manual trans) and push the car with the top of the front tire. Easy to precisely move the timing mark. If you have an automatic..........nevermind.
          • Bill S.
            • January 31, 2007
            • 396
            Re: Don't bump the engine to move the timing mark.
            i bumped it testing the starter after i installed my new engine harness. operating on full brain power again, i think.
