Chevrolet - but not Corvette - 1955 - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    One of the "legends" surrounding Ed Cole and his minions was that when the 1955 Chevrolet appeared, the only things carried over from 1954
    were the 6 cylinder (for those who did not know what they were missing!),
    the Powerglide, the 3 speed manual transmission and the 3 speed with overdrive.
    Your thoughts and comments please.
  • Verle R.
    • March 1, 1989
    • 1163
    Re: Chevrolet - but not Corvette - 1955
    Loren,
    The frame and running gear were different, the body sure was.
    Roy Braatz may be able to name some small parts that were interchangeable but I sure don't know of any.
    Verle
    • Roy B.
      • February 1, 1975
      • 7044
      What are we talking about 54 to 55 Car or 54 to 55 Corvette or parts from a car to Corvette??
      • Mike M.
        • May 31, 1974
        • 8389
        no overdrive in pre-55 chevys . the pre-55's trannys, with their torque-tubes, were dis-similiar from the open drive style 55 up chevy trannys. that what you were looking for, loren? regards, mike
        • Loren L.
          • April 30, 1976
          • 4104
          Yep - Thanks Mike. Just trying to make
          sure of factual data and what Chevrolet did as a lead-in to a "1956 Revisited" presentation at Las Vegas. Maybe it should start right here with a question: "How many 1956 Corvettes raced at Sebring in the 1956
          Twelve Hours race?".
            Re: Yep - Thanks Mike. Just trying to make
            Loren -
            Older sixes had cast iron pistons and "dippers" on the rods for splash lubrication of the rod bearings; don't remember when they changed to aluminum pistons and full-pressure lubrication to the rod bearings.
            • Mike M.
              • May 31, 1974
              • 8389
              the full pressure 235 was introduced as a powerglide optioned chevy in 52 or 53. at least by 55, all the 235's had the full press system. i've got a 53 chevy fire truck with a full press system 235 and i've also got a 1 1/2 ton dually 53 chevy truck with a 235 with dippers on the rods. both engines are original to the two chevy trucks.my first car, a 49 chevy coupe, had the 216 rod dipper oil system. took me about 2 weeks to grenade that baby.those dippper engines don't live long above 4000 rpm.mike
              • Loren L.
                • April 30, 1976
                • 4104
                That's because most of those engines
                can't get to 4000 rpm.......I forget the fellows name - and I suspect that his success was in the lack of knowledge of his "countrymen" - who, in the late 50's/early 60's, was able to "sell" his losers that his GMC 302 was a regular Chevy "6".
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  1953 std shift cars had 216 with dippers and
                  the power glide cars had a 235 with full pressure oil system. my first "new" car was a 53 chevy and i drove a PG car with full pressure oil system. when i picked up my std shift car i noticed the oil pressure gauge did not go up a high in numbers,i think it only went to 30# and the PG cars went to 60#
                  • Joseph T.
                    • April 30, 1976
                    • 2074
                    Re: 1953 std shift cars had 216 with dippers and
                    Clem..it is amazing what people remember!
                    Joe
                    • Clem Z.
                      • January 1, 2006
                      • 9427
                      after installing split exhaust manifold and dual
                      exhaust,dual carbs and a dual point ignition it pitched the rods out. the spash system did not like the RPMs. the service manager at the dealership was the dad of a friend of mine so they covered it under the warranty. i even talked them into a 261 truck engine with full pressure oil system. i had much fun blowing off the "new" 1954 OHV ford V-8s. the guy that owned the dealership turned out to be a great friend because when i bought my 1955 "power pak" V-8 chevy belaire he would foat me loans to bet when i would race the fords from the dealership across the street.
                      • Joseph T.
                        • April 30, 1976
                        • 2074
                        Re: after installing split exhaust manifold and du
                        Clem..
                        Do you know any background on Johnny Beauchamp?
                        Joe
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          sorry i can not help you there. i remember
                          seeing him race but that is about it. did you try and "google" his name ?
                          • Verne Frantz
                            Clem, I hope you last a long time. An Icon *NM*
