C2:67 Signal Switch Connector - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Anyone have a picture of the correct 67 signal switch wiring routing under the dash, and what brace the curved harness connector is supposed to clip to. I have the AIM and it is sure confusing of where and what brace the little clip on the connector clips to.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2:67 Signal Switch Connector
    Jerry, I got gigged on this very item. It took awhile to figure out. Look at UPC 12 B3 Instrument panel wiring in your AIM.
    The flat cable comes out of the bottom side of the column, around the right side of the steering column bracket, and over the column to the left side. The clip is placed on the left side of the pedal brace where it is horizontal and at right angles to the firewall; about 2 inches back from the firewall. This brace point is above the column centerline.
    Photo looking up at the steering column.....Top of photo is instrument cluster.
    Photo looking toward firewall and brace.....
    • Gerard F.
      • June 30, 2004
      • 3806
      Thanks Steve,
      Holy Cow, I would have never figured that out from the AIM page. And opposite curvature to the steering column, how illogical.
      Gonna put it in the right place tomorrow. Two blue gigs for you.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
