RADIO INVERTER 1958 - NCRS Discussion Boards
RADIO INVERTER 1958
  • Joe C.
    • April 30, 2001
    • 126
    RADIO INVERTER 1958
    I AM TRYING TO REPAIR A 1958 RADIO- IT HAS BOTH TUBES & TRANSISTORS- iS THERE AN INVERTER THAT IS ALSO WITH IT (UNDER THE DASH) OR IS THERE AN INVERTER BUILT IN TO THE RADIO- ANY HELP IS APPRECIATED.
  • William C.
    • May 31, 1975
    • 6037
    Re: RADIO INVERTER 1958
    The power supply is built into the radio
    Bill Clupper #618
    • Phil P.
      • April 1, 2006
      • 409
      a lot of the old gm radios used an "OZ4" ocillator (sp) which i think you are refering to as the inverter---use to get these at the liquor stores etc.---they had a self serve machine that you could test you tubes on and the new tubes were stored below---good luck
